DIMANGULAR command
Creates an angular dimension.
Icon:
Alias: DAN, DIMANG
描述(D)
Creates an angular dimension by selecting an entity or specifying the vertex and both sides of the angle. The dimension is based on the current dimension style. Options allow you to specify the angle and contents of the dimension text.
Methods to create an angular dimension
This command has 2 methods to begin creating an angular dimension:
- 选取线、弧或圆
- 按回车键指定角度
- Select line, arc or circle
- Begin creating an angular dimension by selecting a line, arc, or circle to dimension then:
- 选取第二条线
- Specify another line segment.
- 指定标注弧线位置
- Specify the location of the dimension arc.
- 指定标注弧线位置
- 定角度的第二个端点
- Specify a point to define one side of the angle. The point where you first selected the circle defines the other side of the angle.
- 指定标注弧线位置
- 按回车键指定角度
- Begin creating an angular dimension by specifying the vertex of the angle then:
- 定角度的第一个端点
- 定角度的第二个端点
- Specify a point to define the other side of the angle.
- 指定标注弧线位置
Options within the DIMANGULAR command
After you begin creating an angular dimension, the following options may be available:
- 角度
- Specify the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- 文字(T)
- Enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
