DIMCENTER command
Creates a center mark.
Icon:
描述(D)
Create a center mark at the center of a circle, arc or polyarc. See the CENTERMARK command to create associative center marks.
Methods to create a center dimension
There is one method to begin creating a center mark.
- 选取要标注的弧或圆
- 选取要标注的弧或圆
- Begin creating a center dimension by selecting an arc, polyline arc segment, or circle. The DIMCEN system variable controls the length and appearance of the center mark lines.
Options within the DIMCENTER command
After you begin creating a center dimension, the following options may be available:
