DIMLEADER command
Creates a leader.
Icon:
描述(D)
Creates a leader by specifying a sequence of points. The leader is based on the current dimension style. Options allow you to specify the format and annotation of the leader.
Methods to create a leader
There is one method to begin creating a leader:
- 引线起点
- 引线起点
- Begin creating a leader by specifying a start point then:
- 下一点
- Specify the next vertex of the leader.
- 下一点
- Specify the next vertex. You can continue adding unlimited vertices until you press Enter to access the annotation option.
- 注释
- Enter the first line of annotation text and press Enter or press Enter without entering text to access dimension text options.
- 输入下一行批注文字
- Enter the next line of annotation text. You can continue adding lines of text until you press Enter to end the command.
Options within the DIMLEADER command
After you begin creating a leader, the following options may be available:
- 格式
- Specify if the leader line includes an arrow and whether it has spline or straight segments:
- Arrow: draw the arrowhead.
- None: does not draw the arrowhead.
- Spline: draw the leader line as a spline.
- Straight: draw the leader line as straight segments.
- Exit: exit the Format options.
- 撤销(U)
- Undo the last leader line segment and continue drawing from the previous one.
- Dimension text options [Block/Copy/None/Tolerance/MText]
- Specify the type of annotation to use for the leader:
- 块
- Specify the name of a block in the drawing.
- 复制
- Select an mtext, text, block reference or tolerance entity in the drawing.
- 无
- The leader line is created without annotations.
- 公差
- Specify tolerance using the Geometric Tolerance dialog box.
- 多行文字
- Enter annotation text using the MText editor.
- ? 列出工程图中的块
- Enter * to list the names of all block definitions in the current drawing. You can also use * as a wildcard with other characters.
- Open file Dialog
- Select a .dwg file from the file dialog box to use as an annotation block.
