DIMLINEAR command
Creates a linear dimension.
Icon:
Alias: DIMHORIZONTAL, DIMLIN, DIMROTATED, DIMVERTICAL, DLI
描述(D)
Creates a linear dimension that is horizontal, vertical, or rotated. The dimension is based on the current dimension style. Options allow you to specify the angle and contents of the dimension text.
Methods to create a linear dimension
This command has 2 methods to begin creating a linear dimension:
- 指定第一条延伸线原点
- 选择实体
- 指定第一条延伸线原点
- Begin creating a linear dimension by specifying a point for the first extension line then:
- 指定第二条延伸线原点
- Specify a point for the second extension line.
- 指定标注线位置
- Specify the location of the dimension line. If the two extension points you specified are aligned vertically or horizontally, you are restricted to placing a vertical or horizontal dimension, respectively. If the two extension points you specified are not vertically or horizontally aligned, you can drag the cursor to place either a vertical or a horizontal dimension.
- 选择实体
- Begin creating a linear dimension by pressing Enter then:
- 选取要标注的对象
- Select a line, polyline segment, arc, or circle to dimension. When selecting a line, the endpoints of the line are used for the extension origins. When selecting an arc, the endpoints of the arc are used for the extension origins. When selecting a circle, the quadrants of the circle are used for the extension origins.
- 指定标注线位置
- Specify the location of the dimension line. If the endpoints of the entity you selected are aligned vertically or horizontally, you are restricted to placing a vertical or horizontal dimension, respectively. If the endpoints of the entity you selected are not aligned vertically or horizontally, you can drag the cursor to place either a vertical or a horizontal dimension.
Options within the DIMLINEAR command
After you begin creating a linear dimension, the following options may be available:
- 水平(H)
- Specify the location of the dimension to place it in the drawing. This creates a horizontal dimension regardless of how the endpoints are aligned.
- 垂直(V)
- Specify the location of the dimension to place it in the drawing. This creates a vertical dimension regardless of how the endpoints are aligned.
- 旋转(R)
- Specify an angle for the dimension then:
- 指定标注线位置
- Specify the location of the dimension line. The dimension is rotated from its default (vertical or horizontal) location by the specified angle.
- 角度
- Specify the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- 文字(T)
- Enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
