DIST command
Reports the distance and angle between two points.
Icon:
Alias: DI
Method
The distance can be measured between two points or multiple points.
Note: When DRAGSNAP = ON and the Dynamic Dimensions are
enabled, the distance is displayed in the dynamic entry field when hovering over
the second point using an appropriate entity snap.
Options within the command
- Multiple points
- Allows to measure the total distance between multiple points.
- Arc
- Allows to specify an arc distance.
- Angle
- Specify the angle for the arc.
- Radius
- Specify the radius of the arc.
- Center
- Specify the center of the arc. Hold CTRL key to switch direction.
- Direction
- Specify the direction of the arc.
- Line
- Allows to specify a line distance.
- Length
- Allows to add a distance.
- Undo
- Removes the last point.
- Total
- Prints the total length in the Command line and concludes the command.
