DISTANTLIGHT command
Places distant lights for renderings.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Icon:
Places distant lights for use with renderings. Distant lights represent sources that are far off, such as the sun, and so does not display a glyph in drawings.
Note: having DEFAULTLIGHTING=1 will open a dialog box where you are asked.
Options
Name
Specifies a name for the light.
Intensity factor
Indicates the relative brightness of the light.
Status
Toggles the light on and off
Photometry
Specifies the parameters for color and intensity.
shadoW
Specifies the look of shadows, if any.
filterColor
Sets the color of the light.
Vector
The direction of the light beams can be defined by a vector, whose XYZ tuple determines the direction of the light, starting at infinity. The default direction points up, in the Z direction.
Unlike regular vectors, this lighting vector specifies only direction, not magnitude.
1: Distant light illuminating from default vector direction.
