DMANGLE3D command
Creates an angle constraint between faces and/or edges of 3D solids, WCS subentities and subentities of a coordinate system of a block.
Icons:
描述(D)
Creates an angle constraint between faces and/or edges of 3D solids, WCS subentities, and subentities of a coordinate system of a block. Creates a Planar Angle constraint by default: coordinate planes of the WCS are used as third reference objects whenever possible. It also allows to control the top angle of a cone. Press the TAB key to select obscured geometry.
选项(O)
锥角度约束
Allows you to control the top angle of a cone by specifying the angle between the axis and the cone face (= cone half angle). Values must be smaller than 90°.
世界
Allows you to select the WCS subentity as an argument.
图块
Allows you to choose, as an argument, the subentity of the coordinate system of the block. You can choose from: X axis/Y axis/Z axis/XY plane/YZ plane/ZX plane.
设置参考对象
Allows you to manually specify the reference entity:
保持原样
allows you to keep the proposed reference object;
世界
allows you to select the WCS subentity as an argument;
图块
allows you to choose as an argument the subentity of the coordinate system of the block;
creates Angle constraint instead of Planar Angle constraint, without third argument.
几何驱动
Accepts the current value and creates a geometry-driven constraint.
