DMAUDIT command
Analyzes and repairs errors.
Icon:
描述(D)
It is a powerful tool to analyze and automatically fix problems in 3D geometry supported by ACIS kernel (3D solids, surfaces).
Note: It is recommended to run DMAUDIT whenever 3D geometry is imported.
Methods
There are two methods to audit the drawing by selecting one or more entities or the entire model:
- Check problems
- Fix problems
Options within the command
- 检查
- Checks the 3D geometry in the drawing for errors without fixing them.
- 固定(F)
- Repairs errors.
- 设置(S)
- Audits the drawing in function of one of the options you select.
- 后
- Returns to the main prompt of the command.
- 报告面板
Redirects the output of the command to the Report panel.
Note: Depending on the value of REPORTPANELMODE variable, it might be necessary to click on the red exclamation mark in the lower right corner to see more details in the Report panel.
- 复制到文件
- Reports the output of the command in a file.
- 检核等级
- Sets the strictness of the check.
- 低
- Runs basic analysis (for example, catching common fatal topology errors).
- 高
- Goes deep (for example, catching self-intersections in solid bodies).
- 中间(M)
- This is the default level.
- 重合面
- Checks and fixes coincident faces. Requires audit level set to High.
- 嵌套块
- Checks and fixes entities in nested blocks.
