DMCOINCIDENT3D command
Applies a coincident constraint between two subentities of 3D entities.
Icons:
方式
Applies a coincident constraint between two edges, two faces, an edge and a face or a vertex and a face or edge of two different solids or surfaces.
Select the two cylindrical (circular or elliptical), spherical or conical surfaces between which a concentric constraint will be applied. Press the TAB key to select obscured geometry.
选项(O)
- Autoconstrain
Automatically creates a coincident constraint between each pair of connected faces in selection of solids.
You can check which constraints are created in the Mechanical Browser panel or in Parameter and Constraints panel.
- 世界
- Allows you to select the WCS subentity as an argument.
- 图块
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
