DMCOINCIDENT3D command
Applies a coincident constraint between two subentities of 3D entities.
Icons:
Method
Applies a coincident constraint between two edges, two faces, an edge and a face or a vertex and a face or edge of two different solids or surfaces.
Select the two cylindrical (circular or elliptical), spherical or conical surfaces between which a concentric constraint will be applied. Press the TAB key to select obscured geometry.
Options
Autoconstrain
Automatically creates a coincident constraint between each pair of connected faces in selection of solids.
You can check which constraints are created in the Mechanical Browser panel or in Parameter and Constraints panel.
WOrld
Allows you to select the WCS subentity as an argument.
BLock
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
