DMCOPYFACES command
Copies a feature from a 3D solid.
Icon:
Copies a set of 3D solid faces forming a protrusion or depression feature, such as holes, pockets, extrusions, ribs, and their combinations within the same 3D solid or from one 3D solid to another.
Options within the command
Select entities
Select all faces of the entire feature.
Base point
Specify the base point.
Insertion point
Allows you to select an insertion point.
Rotate
Rotates the faces around the Z axis of the UCS.
mUltiple
Insert multiple copies of a feature.
MOde
Toggles between various cutting options.
Placement Face
Cuts the copied feature so that it suits the placement face.
Select Faces
Cuts the copied feature so that it suits the selected face.
No Cut
Does not cut the copied feature.
