DMDEFORMCURVE command
Deforms 3D solids or surfaces by replacing their edges with given curves.
Icon:
描述(D)
Deforms one or more connected faces of a 3D solid or a surface by replacing their edges with given curves.
Select the edges that will be replaced with the target curves to get the new 3d solid or surface.
选项(O)
- add Faces
- Allows to select additional faces, other than the faces adjacent to selected edges, to deform.
- Multiple edges
- Allows the deformation of a chain of edges to a single target curve.
