DMDISTANCE3D command
Applies a distance constraint between two entities.
Icon:
描述(D)
Applies a distance constraint between two subentities of the same solid or of different solids, as well as WCS entities, points, cylinders, and spheres.
Select the two entities/subentities for which the distance constraint will be applied by specifying the distance value. Press the TAB key to select obscured geometry.
选项(O)
使用为
Gives the option to specify how the distance must be measured between cylindrical and spherical faces. The default measurement mode is Axis.
边界(B)
The boundary of the argument.
An argument that has an axis; circle, cylinder, cone, or torus.
中心(C)
An argument that has a central point; circle, sphere or torus.
顶点
A cone vertex only.
世界
Allows you to select the WCS subentity as an argument.
图块
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
几何驱动
Accepts the current value and creates a geometry-driven constraint.
