DMFILLET command
Creates a smooth fillet between adjacent faces sharing a sharp edge.
Icon:
Creates constant or variable radius fillets between adjacent faces that are sharing a sharp edge. After selecting the edges, you may choose to specify a constant radius to fillet edges or one of the available advanced options.
The fillet is applied dynamically and the manipulator is displayed.
Options
- Variable radius mode
Allows to create a variable fillet between adjacent faces that share a sharp edge(s).
Note: All advanced mode fillet procedures start by creating a constant radius fillet, which is then modified by specifying the first, second radius or intermediate points. Before specifying the final value of the radius you can press the TAB key to modify previously specified values.
- Intermediate radius mode
- Allows you to introduce different values for radius for intermediate points.
