DMFILLET command
Creates a smooth fillet between adjacent faces sharing a sharp edge.
Icon:
Creates constant or variable radius fillets between adjacent faces that are sharing a sharp edge. After selecting the edges, you can choose to specify a constant radius to fillet edges or one of the available advanced options.
The fillet is applied dynamically and the manipulator is displayed.
Options within the command
- Variable radius mode
Allows you to create a variable fillet between adjacent faces that share (a) sharp edge(s) by specifying the two end radii.
Note: This option is available only for smoothly connected not cyclical edges.
- Intermediate radius mode
- Allows you to insert intermediate radii by picking points along the selected edges, after specifying a constant radius.
