DMFIX3D command
Applies a fixed constraint to 3D entity.
Icon:
描述(D)
Applies a fixed constraint to a solid or to an edge or a face of a solid.
选项(O)
- 多重(M)
Allows to select multiple entities or subentities like:
- 3D entities: all faces and edges of the 3D solid or surface will be fixed.
- Faces: the selected faces will be fixed and cannot be moved or rotated.
- Edges: the selected edges will be fixed. The adjacent faces can be rotated, but not moved.
- 图块
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
