DMMOVE command
Moves entities or sub-entities.
Icon:
Moves solids, faces, edges or vertices of a solid or inserts using a vector.
You can select one or more entities. Press Enter to stop selecting. To specify the base and the endpoint you can choose one of the following methods:
- Specify a point by clicking the left mouse button.
- Type a value in the dynamic input field.
The selected geometry moves dynamically.
