DMPARALLEL3D command
Applies a parallel constraint between subentities of 3D entities.
Icon:
Method
Select two faces of a solid or two faces of different solids or surfaces or a face and an edge of two different solids between which the parallel constraint will be applied. Press the TAB key to select obscured geometry.
Options
WOrld
Allows you to select the WCS subentity as an argument.
BLock
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
