DMPERPENDICULAR3D command
Applies a perpendicular constraint between two subentities of two 3D entities.
Icon:
Applies a perpendicular constraint between faces or edges of a solid, or of different solids or surfaces.
Select the two subentities of the 3D entities between which the perpendicular constraint will be applied. Press the TAB key to select obscured geometry.
Options
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
