DMREVOLVE command
Creates 3D solids or surfaces by revolving 2D entities about an axis.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Icons:
Note: The DMREVOLVE command has been unified with the REVOLVE command. Use the REVOLVE command instead.
