DMRIGIDSET3D command
Allows to define a set of entities or subentities as a rigid body.
Icon:
Method
Select a set of edges, faces or 3D entities that will be linked as a rigid body.
All members of a rigid set are moved (DmMove command) and rotated (DmRotate command) together, while their relative positions within the rigid set are preserved.
Press the TAB key to select obscured geometry.
Options
WOrld
Allows you to select the WCS subentity as an argument.
BLock
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
