DMSIMPLIFY command
Simplifies the geometry and topology of 3d solid entities.
Icon:
Removes unnecessary edges and vertices, merges seam edges, and replaces the geometry of faces and edges by analytic surfaces and curves, if possible within the user-specified tolerance.
Note: It is recommended to always run this command on imported
3d solid geometry.
Options
- Entire model
- Simplifies the entire model.
- SEttings
- Allows to access the command settings.
- Geometry
- Define the geometrical settings.
- Topology
- Define the Topology settings.
- ON
- Switches topological/ geometrical simplification on.
- OFF
- Switches topological/ geometrical simplification off.
