DMSIMPLIFYALL command
Simplifies the geometry in solids, within drawings inserted as external references.
Removes unnecessary edges and vertices, merges seam edges, and replaces the geometry of faces and edges by analytic surfaces and curves, if possible within the user-specified tolerance.
Note: It is recommended to always run this command on imported
drawings with inserted external references.
Options
- Entire model
- Simplifies the entire model.
- SEttings
- Allows to access the command settings.
- Geometry
- Define the geometrical settings.
- ON
- Switches topological/geometrical simplification on.
- OFF
- Switches topological/geometrical simplification off.
- Topology
- define the Topology settings.
- Auto
- Simplifies the detected geometry or topology.
