DRAWORDER command
Changes the display order of overlapping entities.
Icon:
Alias: DR
描述(D)
This command is used to display entities over the top of other entities that would otherwise overlap or hide them. This command is meant to work with overlapping objects. While this command works with non-overlapping entities, it has no effect on them.
Note: Hatches and text entities in BricsCAD already have handy commands controlling their display order: HatchToBack places all hatching below all other entities, and TextToFront displays all text above all entities.
方式
This command offers 5 methods to change the draw order of overlapping entities:
- 上方
- 下方
- 置于最上方
- Bring to back
- 清除所有排序
Options within the command
- 上方
- Moves the visual display of selected entities above the other entities; this option does not necessarily move them to the top (front) of display order.
- 下方
- Moves the visual display of selected entities under the other entities; this option does not necessarily move them to the bottom (back) of the display order.
- 清除所有排序
- Clears the assigned display orders, with entities displayed as they were originally created.
- 置于最下方
- Moves the selected entities' display order below all other overlapping entities (1).
- 至于上方
- Moves the selected entities' display order above all other overlapping entities (2).
