DUMPSTATE command
Writes information about the current state of the command history
The command is a diagnostics feature that writes some information about the current state of the command history and related internal structures to dumpstate_report.txt file.
Method
Once you encounter a problem with repeating the last command, enter DUMPSTATE at the command line after the incident as soon as possible. The generated file is then placed in the current working directory.
Note: The generated file is overwritten on each DUMPSTATE
run.
