DWGCOMPAREOPEN command
Opens the Compare panel.
Opens the Compare panel to display it in the current workspace. The Compare panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Compare panel can be either floating, docked or stacked.
