ENABLEASSOCVIEWS command
Adds the service data to the drawing and its Xrefs.
It affects only associativity of the section result.
Note: If this command is not called and both
GENERATEASSOCVIEWS and GENERATEASSOCATTRS are turned off, the result will be
visually the same, but not associative.
Method
After the data is added, BIMSECTIONUPDATE and VIEWBASE commands cause no extra modifications in the referenced drawings.
Note: If the drawing contains a Xref file which requires
modification, a message will appear to confirm modification of the Xref
file.
Options within the command
- Proceed
- Toggles between Yes or No.
