EXPBLOCKS command
Opens the Blocks category of the Drawing explorer dialog box for inserting, deleting, and creating blocks.
Icon:
Alias: XB
Note: Non-Uniformly scaled blocks can be exploded only if EXPLMODE system variable is
ON.
Displays the Blocks category of the Drawing explorer dialog box:
Context Menu Options
- New
- Creates new blocks; dismisses the Drawing explorer dialog box, and the starts the -BLOCK command. See BLOCK command.
- Delete
- Deletes the block definition; available only for those block definitions not inserted in the drawing.
- Insert
- Inserts the selected block; dismisses the Drawing explorer dialog box, and the starts the -INSERT command. See INSERT command.
- Insert External
- Inserts DWG files as blocks; starts the INSERT command, and then displays the INSERT BLOCK dialog box. See INSERT command.
- Save Block
Exports the selected block as a DWG file; displays the Save Block dialog box.
Right-click a block to display the shortcut menu, and then choose Options.
- Add to current Toolpalette
- Adds the block to the current Tool Palettes.
- Options
- Displays the Drawing explorer options dialog box to allow you to align, set the scale or the rotation of the inserted blocks.
- Align with view
When checked, inserts the block to face the camera (blocks are rotated about their local Z-axis to face the camera).
Note: Parametric blocks cannot be cut, copied ore renamed.
- Rename
- Renames the selected block.
- Select All
- Selects all blocks definitions.
- Invert Selection
- Inverts the selected blocks. For instance, if you have one block selected, then this option deselects it, and then selects all other blocks.
Options within the command
- Block Name
- Specifies the name of the block.
- Annotative
- When checked, sets the Annotative property.
- Match Orientation to Layout
- When checked, sets the Match Orientation property of annotative blocks.
- Face Camera
- When checked, inserts the block to face the camera (blocks are rotated about their local Z-axis to face the camera). See the CAMERA command.
- Explodable
- When checked, blocks of this definition can be exploded into its component parts by the EXPLODE command. Non-Uniformly scaled blocks can be exploded only if EXPLMODE system variable is ON.
- References
- Reports the number of insertions of the block in the current drawing; number is set by the program, and so you cannot change it.
- Insertion Point
- Reports the insertion point of the block; reports "Varies" when the block has been inserted in the drawing more than once.
- Parametric
- Indicates if the block is parametric or not.
- Linked to file
- Shows file path for External Parametric blocks
- Description
- Optional description of the block.
