EXPLAYERS command
Opens the Drawing explorer dialog box with Layers selected.
Icon:
Opens the Drawing explorer dialog box with Layers category selected to view and modify layers in the current drawing.
: current layer with viewport overrides.
: layer with viewport overrides.
: empty layer with viewport overrides.
Context Menu Options
- New
- Create a new layer definition into the drawing. The new layer that is created copies the properties of the currently selected layer.
- Delete
Deletes layer definitions from the drawing. The following layer definitions cannot be deleted:
- Layer 0
- Defpoints
- Layers in use
- The current layer
- Merge to…
Opens the Merge Layers dialog box. Here you can choose a target layer where the selected layers will be merged to.
The following layer definitions cannot be merged:
- Layer 0
- Defpoints
- The current layer
Note: you can only merge layers which are in use. If there aren’t any entities assigned to a layer, the merge option will delete the selected layer.
- Remove from group
- Removes layers from the group they are assigned to.
- Create Group Filter From Selection
- Creates a group with the selected layers assigned to it.
- Rename
Renames the selected layer.
Following layers can not be renamed:
- Layer 0
- Defpoints
- Select All
- Selects all layers.
- Invert selection
- Deselects the current selection and vice versa.
- Remove Viewport Overrides
- Removes overrides from properties that were set differently for viewports.
- From Selected Layers
- For current viewport: removes overrides from the current viewport
- For all viewports: removes overrides from all viewports in the drawing
- From All layers
- Removes the overrides form all layers in the drawing for either the current viewport or all viewports.
- Isolate Selected Layers
- Dims the entities on all which are not selected. Use the LAYUNISO command to unisolate layers.
Options within the command
- Filters
- You can think of layer filters as "layer groups," groups of layers that you need to show or turn on-or-off all at once.
- New Properties Filter
- Creates a new properties filter. Displays the Layer Property Filter dialog box.
- New Group Filter
- Creates a new group filter.
- Layers state
Toggles the layers state of all the layers in the selected group.
- On: toggles the layers on.
- Off: toggles the layers off.
- Thaw: thaws the layers.
- Freeze: freezes the layers.
- Lock: locks the layers.
- Unlock: unlocks the layers.
- Isolate layers
Isolates the layers in the selected group.
- Current viewport: removes overrides from the current viewport.
- All viewports: removes overrides from all viewports in the drawing.
- Add layers from selection
- In the selected layer group filter, the layers from the selected objects in the drawing are added.
- Replace with layers from selection
- The layers from the selected group filter are replaced with the layers of the selected objects in the drawing.
- Add layers from panel selection
- Adds the layers which are selected in the layers panel.
- Paste with Layers
- Pastes the copied or cut group, including its layers.
- Convert to Group
- Converts a property filter to a group filter.
