EXPORT command
Opens the Export drawing as dialog box.
Icon:
Alias: DWFOUT, EXP
Opens the Export Drawing As dialog box to save the data from the current drawing to a variety of file formats.
Supported file formats for export, depends on the license level, are:
- BricsCAD Lite
- FBX binary file (.fbx)
- FBX ASCII file (.fbx)
- AutoCAD Drawing (dwg)
- AutoCAD ASCII DXF (dxf)
- Drawing Template (.dwt)
- Bitmap file(2) (.bmp)
- Windows Meta File (.emf)(1) (2)
- Enhanced Windows Meta File (.wmf)(1) (2)
- 3D DWF v6.01 (.dwf)
- Binary DWF v6.0 (.dwf)
- Zipped ASCII Encoded 2D Stream DWF v6.0 (.dwf)
- Compressed DWF v5.5 (.dwf)
- Binary DWF v5.5 (.dwf)
- ASCII DWF v5.5 (.dwf)
- Compressed DWF v4.2 (.dwf)
- Binary DWF v4.2 (.dwf)
- ASCII DWF v4.2 (.dwf)
- XPS DWFx (.dwfx)
- Scalable Vector Graphics (.svg)
- Lithography (.stl)
- Collada file(.dae)
- Micro Station DGN File (.dgn)
- BricsCAD Pro
- Unreal Datasmith (.udatasmith)(1) (2)
- Rhino file (.3dm)(1) (2)
3D PDF: .pdf
- Assembly ACIS file (.asat)
- Assembly ACIS file (.asab)
- BricsCAD BIM / Mechanical / Ultimate
- IFC2x3 file (.ifc)
- IFC4 file (.ifc)
- IFC4x1 (.ifc)
(1) Not available for BricsCAD for Linux.
(2) Not available for BricsCAD for macOS.
Note: If the EXPORT3DPDFWRITER system variable is set to 1
(Internal 3D PDF writer), and you save the drawing as a 3D PDF file, the
Select animation dialog box is displayed:Choose an animation to export (1) and set the required number of frames per
second (fps) (2), or select No exploded view animation to
export the document without animation.
Note: Export to Binary DWF v6.0 (.dwf) takes into account
only the Plot area of the layout or modelspace defined in the
Page Setup. So everything outside the plot area will be removed and or clipped
away.
Note: The EXPORTMODELSPACE, EXPORTPAPERSPACE and EXPORTPAGESETUP
system variables currently are dummies for .dwf exports.
Note: More 3D formats are available through a separate module,
BricsCAD Communicator. You can download it from the Bricsys website.
The import and export procedures using Communicator are controlled through a series of user preferences. See the Communicator section on the Settings dialog box.
Note: To export to a PDF format, use the EXPORTPDF command.
