EXTRACTBLOCKS command
Extracts blocks to individual files.
Method
This command extracts a block instance from a drawing, creating a separate .dwg file in a user-specified location.
After selecting a block to extract, the Select Folder dialog box displays to choose the location for the new created .dwg file.
