EXTRIM command (Express Tools)
Trims entities that cross a cutting edge.
Method
Select the cutting edge entity, then click on the side you want to erase the entities from.
Note: The cutting edge entities accepted are: 3D Face, Polyline, Line, Circle, Arc, Ellipse, Image, Text or Attribute Definition.
