FIELD command
Opens the Field dialog box.
Icon:
方式
Open the Field dialog box to create a field in the current drawing. After you select the field and choose OK, you are prompted at the Command line:
- 指定起点
- Specify a point in the current drawing where the field will be inserted.
- 高度
- Specify the height of the field text.
- 对正
- Specify a justification for the field text.
