FIELD command
Opens the Field dialog box.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Method
Open the Field dialog box to create a field in the current drawing. After you select the field and choose OK, you are prompted at the Command line:
- Specify start point
- Specify a point in the current drawing where the field will be inserted.
- Height
- Specify the height of the field text.
- Justify
- Specify a justification for the field text.
