FILLET command
Fillets intersections; joins intersecting lines with an arc of any suitable radius.
Icon:
Alias: F
Sets a radius value for fillet between two entities.
The entities could be:
  • Lines, including parallel lines
  • All vertices of a single 2D polyline; two polylines cannot be filleted
  • Rays, including parallel rays
  • Infinite lines, including parallel infinite lines
  • Arcs
Note: Press and hold the Shift key when select the second entity to create a corner (radius = 0). The selected entities are extended or trimmed at the intersection point. The selected part of the entities is kept.
Note: If the second entity is parallel to the first entity the entities are connected by a semicircle. If the parallel entities are not of equal length, then the second entity is extended or trimmed when Trim Mode = Trim.
Options
fillet Settings
Displays the Chamfer/Fillet section of the Settings dialog box:
  1. Fillet radius - sets the radius of the fillet arc.
  2. Trim mode - toggles whether the entities are trimmed back to meet the fillet radius.
Polyline
Fillets the all vertices of a polyline.
Radius
Toggles edge mode.
Trim
Sets the trim mode for chamfers and fillets:
Trim
Trims or extends the selected entities.
No trim
Creates the chamfer or fillet, but leaves the selected entities unchanged.
Undo
Undoes the last fillet when in Multiple mode.
Multiple
Lets to create additional fillets using the same settings without having to restart the command.
