FITPOLYLINE command
Fits polylines to entities.
Icon:
Draws one or multiple polyline entities, fitted to the characteristic points of the input entities. The command minimizes accumulated perpendicular distances to the points of the selected entities. The command works with every type of entity, as long as it has characteristic points.
Method
There are two ways to define the input to the FITPOLYLINE command:
- Select fitting entities: choose the entities to which the polyline should be fitted.
- Use entire drawing: select all non-frozen entities in the current viewport.
Pick a point for Start of polyline. The guideline is used as a visual aid for the
user, helping to pick the envisioned polyline vertices.
Options within the command
- Start the polyline
- Choose a point and start the polyline.
- fit Lines
Fits a linear polyline segment to the points between the last fixed polyline vertex and the mouse position.
Note: See the FITLINE command.
- fit Arcs
- Fits an arc polyline segment between the points between the last fixed
polyline vertex and the mouse position.Note: See the FITARC command.
- Best fit
- The algorithm automatically decides whether a linear or an arc polyline
segment is best suited to fit the points between the last fixed polyline
vertex and the mouse position.Note: If the Hot Key Assistant system variable is set ON, press the Ctrl key to cycle between the fit options.
- Undo
- Undoes the last action.
- Close polyline
- Closes the polyline.
- start New polyline
- Starts a new polyline.
Note: Press the Esc key once to end the current polyline and
start a new polyline.
Note: Press the Esc key twice to finish the command.
- Finish
- Finishes the command.
