GATTE command (Express Tools)
Changes the attribute values for all instances of a specified block.
Method
- Enter a block name or select an attribute.
- Enter the new text.
- Reports the number of blocks found and changes the attribute value.
Options within the command
- Yes
- Automatically changes all attribute values.
- No
- Allows you to select the attributes you want to change.
