GCCOINCIDENT command
Creates a coincident geometric constraint on 2D entities.
Icon:
描述(D)
Creates a coincident constraint to ensure a point on an entity remains coincident with a specified point or entity.
Methods to create a coincident constraint
This command has 3 methods to begin creating a coincident constraint:
- 选取第一点
- Entity
- Autoconstrain
- 选取第一点
- Begin creating a coincident constraint by specifying a point on an entity then:
- 选取第二点
- Specify a point on an entity to make coincident with the first point. The point on the first entity maintains its position while the second entity adjusts, as necessary, to become coincident.
- Entity
- Begin creating a coincident constraint by selecting an entity then:
- 指定一点
- Specify a point on an entity to make coincident with the first entity. The first entity maintains its position while the point on the second entity adjusts, as necessary, to become coincident.
- Autoconstrain
- Create coincident constraints by selecting all entities to which you want to apply relevant coincident constraints.
Options within the GCCOINCIDENT command
After you begin creating a coincident constraint, the following option may be available:
- 多重(M)
- Create multiple coincident constraints until you press Enter to end the command.
