GCEQUAL command
Creates an equal geometric constraint on 2D entities.
Icon:
描述(D)
Creates an equal constraint to ensure circular entities maintain equal radii or linear entities maintain equal lengths.
Methods to create an equal constraint
This command has 2 methods to begin creating an equal constraint:
- 选取第一个对象
- 多重(M)
- 选取第一个对象
- Begin creating an equal constraint by selecting an arc, circle, line, or polyline segment then:
- 选取第二个对象
- Select a similar entity to make equal to the first. The first entity maintains its radius or length while the radius or length of the second entity updates to match the first entity.
- 多重(M)
- Begin creating more than one equal constraint by specifying the Multiple option then:
- 选取第一个对象
- Select an arc, circle, line, or polyline segment.
- Select entity to make equal to the first
- Select a similar entity to make equal to the first. Continue selecting similar entities until you press Enter to end the command. The first entity maintains its radius or length while the radius or length of all subsequent entities update to match the first entity.
