GCPARALLEL command
Creates a parallel geometric constraint on 2D entities.
Icon:
描述(D)
Creates a parallel constraint to ensure linear entities remain parallel to each other.
Methods to create a parallel constraint
This command has 1 method to create a parallel constraint:
- 选取第一个对象
- Select First Entity
- Begin creating a parallel constraint by selecting a linear entity then:
- Select Second Entity
- Select a second linear entity to make parallel to the first. The first entity maintains its position while the second entity moves, as necessary, to become parallel to the first entity.
