GCPERPENDICULAR command
Creates a perpendicular geometric constraint on 2D entities.
Icon:
描述(D)
Creates a perpendicular constraint to ensure linear entities remain perpendicular to each other.
Methods to create a perpendicular constraint
This command has 1 method to begin creating a perpendicular constraint:
- 选取第一个对象
- Select First Entity
- Begin creating a perpendicular constraint by selecting a linear entity then:
- Select Second Entity
- Select a second linear entity to make perpendicular to the first. The first entity maintains its position while the second entity moves, as necessary, to become perpendicular to the first entity.
