GEOMAPIMAGERESOLUTION command
Sets the resolution for a map image.
Sets the resolution for the map image that was created with the GEOMAPIMAGE command.
Options within the command
- Coarse
- Sets the resolution of the map image to a less detailed view.
- Optimal
- Sets the resolution of the map image to an optimal detailed view.
- Fine
- Sets the resolution of the map image to a high detailed view.
- VeryFine
- Sets the resolution of the map image to a very high detailed view.
