GRADING command
Creates a graded surface on existing topo surfaces.
Icon:
Creates a graded surface between a selected entity and a TIN surface or an offset or slope graded surface from a selected entity.Select the entity to define a graded surface, select the target TIN surface to create a graded surface and move the mouse to adjust the slope of the grading.
Options
slOpe/offset
Sets either the slope or offset option of the grading.
Note: The offset-slope projection method requires input entity, offset, and slope.
