GRADINGEDIT command
Splits or merges gradings.
Icon:
Merges two gradings into one with several regions with (automatic) calculation of transitions between gradings, or splits the grading into multiple regions so that the slopes for each region can be edited separately.
Select a grading to be split into multiple regions, or to be merged with another grading.
Options
- Split
- Splits the grading into multiple regions, so the slopes for each region can be edited separately by moving the grips.
- Merge
- Merges two gradings into one.
- Switch
- Switches the direction.
