GRAPHICOVERRIDE command
Temporarily modifies the appearance of entities in 3D model space.
Icon:
Method
GRAPHICOVERRIDE is a 3D drawing customization feature that allows you to temporarily override the visual appearance of a specific selection of objects based on BIM properties.
The command opens the 3D Graphic Override command panel to allow you to define which entities in the 3D model space will be overridden and how their appearance should be modified.
- Filter
- Override
- Other entities
- Live
- Apply
- Clear
- Cancel
- Filter
- Allows you to define which entities in the 3D model space will be overridden by setting one or multiple criteria based on BIM properties, quantities, or custom properties. Filter rows can be added to filter by multiple parameter combinations. These rows are separated using the logical "OR" operation. The rows can be copied by clicking the copy symbol or deleted by clicking the delete symbol.
- Override
- Allows you to define how the filtered entity will be visualized.
- Other entities
- Allows you to define how all other entities, that do not meet the filter criteria, will be shown in the drawing.
- Live
- By enabling the Live mode, every change you make to the settings is immediately applied to the model.
- Apply
- Applies the current settings to the 3D model of the opened document. This will overwrite any existing override on that model.
- Clear
- Clears any existing override of the current open document.
- Cancel
- Closes the command panel keeping the override active on the 3D model.
