HATCHEDITEXT command
Edits the vertices of a hatch or gradient entity.
Edits the vertices of a hatch or gradient entity interactively through the command line.
Options within the command
- Add vertex
- Adds vertices by stretching selected grip points.
- Remove vertex
- Removes vertices.
- convert to Line
- Converts arc segments to line segments.
- convert to ARc
- Converts line segments to arc segments.
