HIDEOBJECTS command
Hides selected entities.
Icon:
Hides selected entities, like using the Freeze option of the Layer command but for individual entities. Hidden entities optionally stay hidden between drawing sessions.
Note: To return hidden objects to view, use the UNISOLATEOBJECTS command.
Note: The OBJECTISOLATIONMODE system variable controls whether the hidden state is saved or not.
Note: The HIDEOBJECTS command is enabled under BEDIT and REFEDIT sessions.
