LANDXMLEXPORT command
Exports Civil entities to a LandXML file.
Allows you to select the BricsCAD Civil entities you want to export to a LandXML file. Once the entities are selected, the Save LandXML file dialog opens, where you can specify the location and name of the output LandXML file.
Method
Select Civil points, TIN surfaces, gradings or Horizontal Alignments and 3D Alignments in the drawing and specify the output file.
