LANDXMLIMPORT command
Opens the Open land XML file dialog box.
描述(D)
Opens the Open land XML file dialog box to select an xml file to import. After choosing Open in the dialog box, you are prompted at the Command line:
- 将断线绘制为多段线
- Specifies if breaklines are imported as polylines.
