LAYMRG command (Express Tools)
Merges layers of selected entities into a destination layer.
Icon:
Method
Select the entities on the layers to be merged and then select an entity on the target layer.
Note:
- The entities on the merged layers are moved to the target layer.
- The merged layers are purged from the drawing.
Options within the command
- Type-it
- Allows you to enter the layer name.
- List
- Allows you to enter the layer name(s) to list.
- Lists all available layers.
- Do you want to continue?
- Yes
- The merged layers are purged.
- No
- Exits the command, without merging the layers.
